Steering wheel silver trim.
FOC_reaper
Drives: Fiesta S140
Post by FOC_reaper »
Is there anyway to remove the silver trim, without removing the airbag?
Cheers
Re: Steering wheel silver trim.
Yes undo the 3 torx screws on the back of the steering wheel, then 'wiggle' it out
FOC_reaper
Drives: Fiesta S140
Legend..
It's one of those things you know to be the case but just wanted to make sure.
mark7-mountune
Drives: mk7 zetec s mountune 140
Post by mark7-mountune »
its really easy mate :dance: i did mine in carbon wrap look in my project thread :ugeek: ..
do it with the engine running then u can turn the wheel to get at the screws easier :whistle:
mark7-mountune
can i ask are you painting it .... and are you gunna do the rest of the silver trim ????
FOC_reaper
Drives: Fiesta S140
mark7-mountune wrote:can i ask are you painting it .... and are you gunna do the rest of the silver trim ????
Door handle and steering wheel trims are changing colour, I'm not doing it though
And the rest has already been done.. pics will be available after Ford Fair. (but not of the steering wheel and door handles trim) :D ;)
