MK7 FIESTA HEADUNIT STAYING ON
Bachu
Drives: Zetec s
Refferer: Search engine
Post by Bachu »
hi theren i was driving home and firstly my bluetooth would not connect and then after that when i got home the headunit just stayed on..
after the key has been taken out..
please help...
many thanks
JackClargo
Drives: Fez mk7 zetecs petrol
Refferer: good old google
Re: MK7 FIESTA HEADUNIT STAYING ON
Post by JackClargo »
Hey, I know you can disconnect the negative on the battery for 20 minutes to form a soft reset :)
Hope that helps
