filler cap to diesel fiesta 2011 zetec s
dave3974
Drives: fiesta 1.6 zetec s diesel
Post by dave3974 »
I want to put an additive in the tank , but i have the fORD SYSTEM THAT WILL ONLY ALLOW a diesel fuel pump nozzle to enter the tank -how do i get around it anyone; More especialy if i ever need to use a can to top up the tank , how do i do it---will i have to push it to a pump ?
@it
Drives: Fiesta
Re: filler cap to diesel fiesta 2011 zetec s
Post by @it »
Check the boot, emergency kit for a pipe that is used for emergency fill up should you run out of fuel.
@it
dave3974
Post by dave3974 »
ta
