A UK Based (Wordwide Members!) Resource Forum Dedicated To The Fiesta Mk7, Mk7.5, Mk8 - All Models Inc. Zetec S, ST, ST180! The number one dedicated resource forum.
Ad blocker detected: Our website is made possible by displaying online advertisements to our visitors. Please consider supporting us by disabling your ad blocker on our website.
I have a cheap jet washer from Homebase (small blue plastic bug-like thing with black wheels) - it must be at least 10 years old and still works fine. Its lance (which has 3 sections - handle , middle section (extension) and nozzle) has brass bayonet connectors which dont seem to correspond with any other connector system Ive found. I bought a foam lance from Amazon and sacrificed the middle section of the jet washer lance - unscrewed its connector and replaced the the foam lance connector with it. It works but only just - I think the problem is that the Homebase jet washer cant deliver enough pressure to to make really thick foam. Ive got an even older Karcher washer and Im going to try that out with the foam lance.
I know this doesnt answer your query but at least you know you are not alone with your connector issue.
