Passenger Side Rattle - SOLVED
ashley14297
Drives: 1.6 Zetec-S
Post by ashley14297 »
Hi all,
New to the forum but thought someone may be interested in a fix for the passenger side rattle - I've seen on a lot of other forums where people have been having the same problem.
My Zetec-S is 7 months old now and a couple of months back it developed a really loud annoying rattle from the passenger side. I couldn't work out where it was coming from at all - it was either the passenger door, back passenger side (where the fourth door would be), or the boot. I spent hours trying to find it, even took it back to Ford but they were useless.
Anyway, this morning I've spent another hour on it and have finally found it! If you take the trim off that surrounds the front seatbelts (it's held on by flimsy clips so be careful as I nearly snapped them) once you have one clip off slide your hand behind the trim and gently pull away from the car and the rest should unclip enough so that you can see the whole seatbelt casing. Right at the bottom of the seatbelt casing (to the right hand side) there is a plastic 'arm' that is feeding a wire through. This is banging against the metal and causing a rattling sound when driving. All I used was a couple of double sided sticky foam pads to secure it in place and now have no rattle :dance: :dance: :dance: !! I started to get the rattle on the driver side as well so have done the same
gotaparel
Refferer: search engine
Re: Passenger Side Rattle - SOLVED
Post by gotaparel »
Thanks, I've been looking for such a review.
Billy_boy11
Drives: 2009 1.25 fiesta
Post by Billy_boy11 »
I have a rattle under the dash on the passenger side but the volume button on the radio fixes that lol
dmulv
Drives: 1.6 TDCi Titanium
Post by dmulv »
Another culprit for rattles is the bit where the plastic forming the stowage bin of the door meets up with the main door panel... there's a join running to the back of the door that can make a lot of noise
