HID Kits???
Bilzaaa
Drives: Fiesta
HID Kits???
Post by Bilzaaa »
I want a HID kit on my Ford Fiesta Zetec S and i dont know what kit to get?
I need one for my dipped beam and full beam at a reasonable price.
Any recommendations / links?
Thanks
HID Kits???
Bilzaaa wrote:I want a HID kit on my Ford Fiesta Zetec S and i dont know what kit to get?
Thanks
Don't bother with full beam and I use kensun 6000k 35w not complaints Image
I do have full beam and fogs as HIDS but full beam is pointless In HIDS as they take time to warm up
Bilzaaa
Drives: Fiesta
Re: HID Kits???
Post by Bilzaaa »
But then ill have 2 different colour since im getting 6000k for diped beam and then normal phillips blue vision for full beam?
HID Kits???
Bilzaaa wrote:But then ill have 2 different colour since im getting 6000k for diped beam and then normal phillips blue vision for full beam?
Yeah you will. I have my full beam as HIDS but your better of using normal bulbs for full beam. Plus remember you won't pass MOT with HIDS it's 2 less bulbs to swap when it goes in
Bilzaaa
Drives: Fiesta
Re: HID Kits???
Post by Bilzaaa »
Any other recommendations?
and maybe a guide on how to fit?
HID Kits???
Bilzaaa wrote:Any other recommendations?
Anything that's not dirt cheap they are all the same really.
For fitting its just like a normal bulb but does differ as you will need to have the bulb go though the cap into the lights. On the fiesta it's only a rubber cap so just cut a small hole and the grommet on the cables will make it watertight. Plug the positive and negative into the original bulb power source and secure the ballast
I know above is only quick explanation but have a go and if you have any issues give me a shout
