eibach spring and warranty
stephens_0n
Post by stephens_0n »
firstly hello, i am after lowering my zetec s and after reading around the eibach springs seem a good choice with it being a ford part.
The confusing part is depending who you ask or what you read people have different views on warranty.
some say if you buy the approved parts anyone can fit it and the warranty is fine
other says you need they purchased and fitted from ford to keep the warranty, generally the view from the dealer. no surprise.
can anyone shed some light on the situation?
thanks
Seans_Fes_Mk7
Drives: Mk7 Style +
Re: eibach spring and warranty
Post by Seans_Fes_Mk7 »
Simple answer to this.
Nothing voids warranty unless it causes need to repair something you might try to have done under warranty.
Mikeypaine
Drives: S1600
Post by Mikeypaine »
Just keep the receipt. But if say a shock absorber fails and it can be proved that its due to incorrect fitment of the springs you can then be held liable for that cost! Otherwise. Crack on, I'm going to!
