Tighten Handbrake?
TonyZetecS
Tighten Handbrake?
Post by TonyZetecS »
Hi ive got a 59 plate zetec s. And ive noticed my handbrakes been getting quite loose recently :(
Anyone know how i can tighten it?
"Tony's Edition" Fiesta Zetec S...
TonyZetecS
Re: Tighten Handbrake?
No one?!
Billy_boy11
Drives: 2009 1.25 fiesta
Post by Billy_boy11 »
Is it drums or discs on the back axle?
Tighten Handbrake?
Billy_boy11 wrote:Is it drums or discs on the back axle?
Drums
Most cars have a nut on the cable which you can tighten found on the hand break end. Not sure on fiesta though
Billy_boy11
Got to remove the drum if you tighten it at the shoes end
wheel off 2 securing screws out the drum and gently prise and tap with a hammer and the drum will come off the with a small screw driver adjust the shoes with the adjuster screw
its a simply job when you done it once
