A UK Based (Wordwide Members!) Resource Forum Dedicated To The Fiesta Mk7, Mk7.5, Mk8 - All Models Inc. Zetec S, ST, ST180! The number one dedicated resource forum.
Ad blocker detected: Our website is made possible by displaying online advertisements to our visitors. Please consider supporting us by disabling your ad blocker on our website.
It comes on a sticky pad, and that is stuck down to a specific type of cable tie that has a square plastic bit built in. (Drilled a hole at the back for it to feed through)
tdgrice11 wrote:Ah good, so will it go on the grill bit next to the ford badge? Or is their a better product i should know about?? Thanks Nath
Personally I would look for a better way of attaching it. Remember you only have the edge of those 2 bars that go across which isn't much surface area for it to stick to.
