Firstly I would like to say Hi!
I've got myself a Mk7 Zetec S Tdci (09) , bought it back in September. Shortly after obtaining the car I had an injector give up on me so had that replaced, at the same time the engine was throwing up fault codes to do with the EGR being either stuck open or blocked, so I had this blanked off at the same time.
Now here comes my problem, at completely random times (start or end of a journey, hot or cold, whenever) the car would lose all boost and then subsequently only rev to just below 4000 rpm, making it very slow and sluggish and almost unbearable to drive. Sometime the EML will light up with the fault code about the EGR, now I put this down to not having the EGR deleted from the ECU when blanking it off. But this is where I struggle to understand the problem and so do the mechanics I've spoken to- to temporarily fix the issue, I could bring the car to a complete stop, the wheels had to be stationary, then set off again and 99% of the time the car fixed itself until the next time which could be a minute later or a week later. It Didn't work by bringing it back down to idle by depressing the clutch or just turning the engine on and off.
I've just had the car Remapped and at the same time had the EGR removed from the ECU at the same time, it was fine for a day but now the same issue has come back, just not quite as sluggish without boost, and once again the same temporary fix.
Has anyone any advice or ideas?
Thanks in Advance.
Ash
Fiesta MK7 Zetec S Tdci Serious Help Needed!
- Newbie (Welcome Me!)
- Drives: fiesta cdci mk7
- Refferer: facebook
Re: Fiesta MK7 Zetec S Tdci Serious Help Needed!
have you checked the injector seals???? its a common issue on these.
and then check your ic hoses for oil
