USB Aggggghhhhh!
Anglia100e
Drives: Fiesta mk7
Re: USB Aggggghhhhh!
Post by Anglia100e »
neilha wrote:Hi,
I gave it 500 miles without exceeding 3000RPM. Then started to exercise it a bit. Will use it fully once I get over a 1000 miles. You probably don't need to run in these days but it's nice to when you've just got a new one.
Cheers, Neil.
Doing exactly the same with mine, at the moment I am on 470 miles and itching to take it up to the next stage. I know it's only 30 miles short but as you say it's nice to do it as it's a new car. At 500 I am going to 4k and then move it up when it gets closer to 1000 miles. At least I know it's been done correctly apart from the 9 delivery miles! :?
I never rag cars so once I have been to max revs a few times I will consider the running in done and go back to driving normally
Cheers
Ken
